CiscoCCMUser
Jun 11th, 2007
Hi all
does anyone know the default password for the CiscoCCMUser sql account?
Is it true, that the sql accounts CiscoCCMReader and CiscoCCMCDR are deleted if
I update the callmanager from 3.3 to 4.2(3)? I just can't find the the users
after the upgrade.
Thanks for feedback
Reto
Overall Rating: 4 (1 ratings)
gogasca Mon, 06/11/2007 - 22:34
  • Green, 3000 points or more
Hi Reto,
I'm almost positive these accounts are no longer used by CallManager in CM 3.3 and later. CCM 3.3(3) was the beginning of a move toward Windows ONLY authentication basically we stopped using SQL accounts.
