Block Internal IP address from all outside access
Answered Question
Jun 11th, 2007
Hi all I am new to the PIX.
How can I block an Internal IP Address from ALL outside access?
And then enable access again, if it is needed?
Correct Answer by acomiskey about 9 years 10 months ago
"Thanks that worked, how can I delete/rename the access list I just recreated?"
no access-list inside deny ip host 192.168.1.10 any
no access-list inside permit ip any any
access-list deny ip host 192.168.1.10 any
access-list permit ip any any
access-group in interface inside
One comment to the other recommendation, this would work as long as the client required nat/pat to get outside. He would still be allowed across vpn tunnels for example. Also, technically it is not denying him from going outside either, it is just not allowing the destination to route back to him.
Overall Rating: 5 (1 ratings)
acomiskey Mon, 06/11/2007 - 08:10
  • Green, 3000 points or more
Are you asking to prevent internal from going outside or outside user accessing internal ip?
It sounds like you want to block an ip from going out since traffic from outside to inside would be denied by default. So, if this is the case you can add an inside acl to the pix...
access-group inside in interface inside
192.168.1.10=ip you are trying to block
inside=name of inside interface
To allow access again, just do...
no access-group inside in interface inside
cadstillo Mon, 06/11/2007 - 08:38
Correct Answer
acomiskey Mon, 06/11/2007 - 09:35
cadstillo Mon, 06/11/2007 - 09:41
Thank you for pointing that out.
Thanks for showing me how to delete and rename, that makes sense.
JORGE RODRIGUEZ Mon, 06/11/2007 - 08:23
Hi, if you have a global NAT Pool for internet or outbound connections you could add the PC host in your inside interface of the pix , for the outside interface don't give the PC global dynamic pool. so this way it will not translate when going outside.
for example: we'll use 192.168.14.44 as the PC-hots
give the PC static NAT for all the interfaces.
name 192.168.14.44 test-pc
pdm location 192.168.14.44 255.255.255.255 inside
nat (inside) 0 192.168.14.44 255.255.255.255 0 0
static (inside,outside) 192.168.14.44 192.168.14.44 netmask 255.255.255.255 0 0
or
to enable access then add the PC to the global NAT pool for outside, usually your public IP pool range or PAT address for the outside interface.
Jorge
cadstillo Mon, 06/11/2007 - 09:19
That is interesting. I will look into doing that.
