Assign management Interface IP address on 6513
rais Mon, 06/11/2007 - 09:55
An IP addresses is needed on sc0 interface:
set interface sc0 1
where 1 after sc0 is the vlan number.
lbrownlee Mon, 06/11/2007 - 11:17
the set command is for catos devices. the other command would be like any other router... in config mode.
interface loopback #
ip adddress 192.168.x.x 255.255.x.x
no shutdown
We typically use Loopback 0 for management but you can use other numbers.
sundar.palaniappan Mon, 06/11/2007 - 11:19
If the switch is running native IOS then you are in the RP and to manage the switch all you have to do is this. Configure a SVI aka vlan interface for the mgmt vlan and assign it an IP from the subnet.
int vlan (mgmt_vlan)
ip address x.x.x.x x.x.x.x
I assigned a loopback on both switches. for SW1
and for SW2
I cannot ping neither from the management PC @
The switch (where Management PC is )port says:
interface GigabitEthernet10/33
switchport mode access
no ip address
interface GigabitEthernet10/34
no ip address
the loopback port says:
interface Loopback0
ip address
All ports show UP-UP yet I cannot ping them or access them via telnet from the management PC.
sundar.palaniappan Tue, 06/12/2007 - 12:03
You have configured g10/33 & g10/44 to be part of vlan 1 and hence, you can configure like this;
int vlan 1
ip address (
I assume this subnet,, belongs to vlan 1 and if it's not then assign int vlan 1 an IP from that subnet. The devices connected to those two ports need to use the int vlan 1 IP as the default gateway.
Edison Ortiz Tue, 06/12/2007 - 12:01
Your management PC is connected to VLAN 1.
I suggest removing the IP from the loopback on the respective switches and assign them under interface vlan 1 and make sure to issue a 'no shutdown'.
sundar.palaniappan Tue, 06/12/2007 - 12:06
Is IP routing enabled in the switch. Either way try adding this command 'ip routing' from the global config mode. Is the interface g10/33 or 10/34 up?
Edison Ortiz Tue, 06/12/2007 - 12:22
Please post the output from the following commands:
show ip int bri | ex una
show int status | i connected
show vlan | ex una
