Problem adding atendant console user after intergrating with active direct
Jun 11th, 2007
I am having problems adding an attendant console after intergrating with active directory. When I go to users and add attendant console ac user it gives me an error.
Hi Brandon,
I have the same issue.
I have 4 cluster with Active Directory, my doubt is if I could use and associated the ''global'' AC user that AD has on other clusters? For example AC gui is currently working on Cluster A with two differents users and I want start to use on cluster b o C o D, is possible?
Do you know what TCP/UDP port use?
Please advise
Andres
