ATA186
Jun 11th, 2007
the ata is connected to a CME. the analog phone connected to this ata does recieve calls, but it can't make calls (no dial tones..).
Do i need to work on the ATA configuration or the CME? and how?
Alf Martinsen Tue, 06/12/2007 - 00:41
You have to register the ATA (if it's not auto reg)then assign it, css, part, dir number
/ama
paolo bevilacqua Tue, 06/12/2007 - 03:12
  • Hall of Fame,
    Founding Member
Which image are you using on the ATA ?
valides007 Tue, 06/12/2007 - 04:30
what do u mean by image?
Let's tell u what i did:
I did all the configuration needed for an ATA in the IP-PBX (Cisco 2821).
It seems that the ATA and the CME are talking. When i make a call from any IP phone to the ATA, it works-you hear the analog phone ringing, but i'm not able to make a call from the analog phone that is connected to the ATA.. Any help?
