Cisco 2821 Serial Interfaces on Ciscoview shows them Admin Down
Jun 11th, 2007
When using Ciscoview 6.1 to display a Cisco 2821 router serial interfaces. Ciscoview shows these interfaces admin down, however the serial interfaces are up and active. How can I clear this status on Ciscoview to show a green status ?
Overall Rating: 4 (1 ratings)
Joe Clarke Mon, 06/11/2007 - 11:21
What is the exact version of CiscoView? What version of the Rtr2800 package are you using (click About while viewing the 2821)? What version of IOS is running on this router? Please provide an snmpwalk of the ifTable from this router.
tom.diaz Mon, 06/11/2007 - 15:41
Thanks jclarke.
We are running Ciscoview 6.1.5. The Rtr2800 device package is 7.0. The IOS version is 12.4(10a). Also, we have other Cisco 2821's that display correctly on Ciscoview showing the serial interfaces green. However for this router, the serial interfaces are grayed out. I don't know where to get the snmpwalk of the ifTable.
Joe Clarke Mon, 06/11/2007 - 17:14
You can use the SNMP Walk tool in Device Center to do this. The starting OID should be "ifTable". What are the differences between the 2821s that show correct interface status, and this one that doesn't?
tom.diaz Wed, 06/13/2007 - 09:48
I'm not a system administrator so I don't have the SNMP Walk feature, however I'll try to get this access from our Ciscoworks Admin.
As for the other 2821 that our working. I compared the routers and found no differences. They have the same IOS and VWIC cards.
Joe Clarke Thu, 06/14/2007 - 07:51
SNMP indicates all but interface GigabitEthernet0/1 are up. In order to troubleshoot this further, I would like to see a screenshot of the problem, and you will need to enable CiscoView debugging for this device. Unfortunately, since CiscoView caches the device model, the best way to get this is to first restart dmgtd then enable SNMP and Activity trace debugging under CiscoView > Administration > Debug Options And Display Log, then open the device, and collect the log.
Joe Clarke Thu, 06/14/2007 - 10:01
Okay, this interface isn't showing up as admin down, it's showing up with no status. This debug output, however, was not done as I requested. CiscoWorks Daemon Manager was not restarted first, and the debug is incomplete. I would also like to see a walk of from this device.
