06-11-2007 11:23 AM - edited 03-14-2019 10:00 PM
Is it possible to register phone over INTERNET to CME 4.1?
How is the NAT configuration?
---IP PHONE with virtual IP------(CME with real IP)-------INTERNET-------(ADSL-NAT)----IP PHONE with virtual IP
06-11-2007 12:24 PM
It depends on the NAT device. If a cisco device, that supports SCCP, there will be no problem. Else, it is better to use SIP on the phone because SIP is generally supported by cheap routers too.
06-20-2007 12:18 PM
Do you know any cheap ADSL Router that supports SCCP
06-20-2007 12:44 PM
Beside cisco, none does. The cisco 85x are not super cheap but cheap enough. The previous models, 83x should be easy to find used on the leading auction site.
