ASA Logging http request inbound from specific network
Jun 11th, 2007
I am trying to determine how many hits our web server is getting from a specific network? Would this be done via an access-list or some other method?
cpembleton Mon, 06/11/2007 - 18:18
  • Silver, 250 points or more
You could add the 'log' keyword to the end of your ACL that permits that traffic. Then send that to a syslog. However, it would be difficult to report on the info. Unless you used something like www.splunk.com which has reporting features.
Your probably better of getting some spealized software or hardware that is made for that. Don't know of any but I know they exist.
Chad
Please rate if helpful.
