ACS 4.1 and accounting
craig.eyre
I'm trying to get my acs server to log all the commands that are used during the users session on a network device. I have everything up and running but it won't log the commands at all. Here is my config for AAA from my 2950 switch.
aaa new-model
aaa authentication login default tacacs+ local
aaa authentication enable default tacacs+ local
aaa authorization commands 1 default tacacs+ local
aaa authorization commands 15 default tacacs+ local
aaa accounting exec default start-stop tacacs+
aaa accounting commands 1 default start-stop tacacs+
aaa accounting commands 15 default start-stop tacacs+
aaa accounting connection default start-stop tacacs+
aaa accounting system default start-stop tacacs+
Can only routers commands be logged by the acs server, or can switches as well. This is a test environment and would like to figure it out. Also, I have nothing showing up under my TACACS+ administration log but have lots under my TACACS+ accounting log. I have enable the administration log on the acs server and nothing changed.
2 Accepted Solutions
ohh sorry , I see its 4.1.
This is a known issue, you need to apply patch ACS 4.1.1.23.5 to fix the issue.
Patch for appliance is availble on
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-soleng-3des')">http://www.cisco.com/cgi-bin/tablebuild.pl/acs-soleng-3des;
Patch name : ACS SE 4.1.1.23.5 accumulative patch
Patch for acs windows is availble on
http://www.cisco.com/cgi-bin/tablebuild.pl/acs-win-3des')">http://www.cisco.com/cgi-bin/tablebuild.pl/acs-win-3des;
Patch Name : ACS 4.1.1.23.5 accumulative patch
That should fix the issue,
Jagdeep
Note: If that answers your question, then please mark this thread as resolved, so that others can benefit from it.
Here is the link,
Jagdeep Gambhir
Level 10
Level 10
Craig,
What is the software ver for acs ?
Jagdeep
Jagdeep
Here is the link,
