trouble blocking telnet on wan side
Answered Question
Jun 11th, 2007
I have a 1721 set up as i guess a router on a stick. Anyway I cannot seem to block telnet on my wan interface. I use 5 IPs on my wan side of my router(from a cable modem) and I can only telnet to the Ip that i set as the interface ip. However, when I try to apply an accesslist it still gets thru. The top line on my acces-list 101 is access-list 101 deny tcp any any eq telnet. Accesslist 101 is is applied inbound in the interface. What else do I need to do to get this to block telnet on that interface
Correct Answer by anandramapathy about 10 years 1 month ago
Right.
Can you confirm that you applied the ACl on the LIne VTY 0 15
access-list 199 permit tcp xx.yy.zz.0 0.0.0.255 any
access-list 199 permit tcp aa.bb.cc.0 0.0.0.127 any
access-list 199 deny ip any any log
line vty 0 4
access-class 199 in
exec-timeout 60 0
Overall Rating: 5 (1 ratings)
spremkumar Mon, 06/11/2007 - 20:28
  • Red, 2250 points or more
Hi Ryan
Can you post the config which you have done over there in your router ?
regds
mtechnology Mon, 06/11/2007 - 21:51
do you deny telnet from outside ?if yes
bellow the configuation
conf t
line vty 0 15
transport input none
if no
past the config for router
Correct Answer
anandramapathy Mon, 06/11/2007 - 22:40
  • Bronze, 100 points or more
Right.
line vty 0 4
access-class 199 in
exec-timeout 60 0
ryancolson Tue, 06/12/2007 - 09:24
I applied the access to the outside interface, which is ethernet0
ryancolson Tue, 06/12/2007 - 09:35
I was wrong. It is only allowing telnet to the outside interface ip from inside.
