Warning message
check the details of active phones / calls on a callmanager
Jun 11th, 2007
Does someone know how to see which calls or phones are active on a callmanager 5.1 ?
I know you can see the number of active calls in RTMT, but is there a way to check which calls are active ?
All feedback is appreciated.
Dirk
htarra Fri, 06/15/2007 - 11:14
  • Bronze, 100 points or more
Go to Programs -> Administrative tools -> Performance Monitor. Select Cisco CallManager and you'll find a number of counters there including Call Active.If you need details you'll have to pull them from CDR database afterwards
dcharlier Sun, 06/17/2007 - 22:14
I knew this, but I wondered if there was no way to see which calls where active ...
