IOS command on CatOS
Jun 11th, 2007
Hello All,
I want to carry out an IOS command on CatOS.
IOS----------------------------------------------------
service timestamps debug datetime localtime
service timestamps log datetime localtime
logging buffered 8192 informational
logging trap debugging
logging facility local1
logging X.X.X.X
aaa authentication login default group tacacs+ line
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ none
aaa authorization commands 1 default group tacacs+ none
aaa authorization commands 15 default group tacacs+ none
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa session-id common
tacacs-server host X.X.X.X
tacacs-server directed-request
tacacs-server key xxx
snmp-server community imsp-isd-com RO
no ip domain-lookup
ntp server X.X.X.X
ntp server X.X.X.X
Is there a corresponding command?
Jagdeep Gambhir Tue, 06/12/2007 - 01:00
  • Red, 2250 points or more
Console> (enable) set tacacs server [IP] [primary]
set tacacs key [key]
set tacacs attempts [number] (optional)
set localuser user [user] password [password] privilege 15
set authentication login local enable
set authentication login tacacs enable [all | console | http | telnet] [primary]
set authorization exec enable tacacs+ [deny | none] [console | telnet | both]
set authorization commands enable [config | all] tacacs+ [deny | none] [console |
telnet | both]
Console> (enable) set accounting exec enable stop-only tacacs+
Console> (enable) set accounting commands enable config stop-only tacacs+
Check this link for more information.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/sw_8_5/cmd_ref/ses_sete.htm
Jagdeep
Note: If that answers your question, then please mark this thread as resolved, so that others can benefit from it.
