hsrp between 2821 router and 3750 switch
Jun 11th, 2007
Is it possible to do hsrp between 2821 router and 3750 switch.
Also whether we can do hsrp between two interface on the same router for link redundancy.
bjornarsb Mon, 06/11/2007 - 23:21
  • Bronze, 100 points or more
According to Feature Navigator 3750 does not support HSRP.
Try bundling instead of HSRP on same router.
BR,
Bjornarsb
mahmoodmkl Mon, 06/11/2007 - 23:22
  • Gold, 750 points or more
I think it is possible to do HSRP between 2821 and 3750.
What is the use of doing HSRP on the same device.Suppose if that device fails then u will not have any redundency.
Mahmood
mohammedmahmoud Mon, 06/11/2007 - 23:33
  • Green, 3000 points or more
Yes you can, both support HSRP, kindly use the Cisco feature navigator to find the correct IOS to use:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Select "HSRP - Hot Standby Router Protocol".
But note, HSRP is applicable only if you have 2 routing devices, if only one router you can't use HSRP, here you are a post that discussed this item nicely:
http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Network%20Infrastructure&topic=LAN%2C%20Switching%20and%20Routing&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddea6a7
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
raj_bjs77 Tue, 06/12/2007 - 00:26
Want to know if i can use HSRP between 2821 and 3750 switch for redundancy.
My one link will be connected to 2821 and other to 3750 switch. I will enable L3 on the switch.
bjornarsb Mon, 06/11/2007 - 23:49
sorry, I did not use CAT37.....
