Static Routes
Answered Question
Jun 11th, 2007
I understand that Static routes are configured manually by network administrators.
I have a doubt in the syntax of the static route command.
Please refer to the image attatchment for the network diagram.
(This is from Boson Simulator which I am practicing)
On Router 1 I give the following command:
ip route 192.168.100.0 255.255.255.0 192.168.1.2
Can anyone explain me why is 192.168.1.2 i.e the address of Serial interface needed here?
Also how exactly this command works.
I am confused here with this command.
Waiting for your reply
Correct Answer by mohammedmahmoud about 9 years 11 months ago
No, what is meant by using the physical interface (outgoing interface) is this:
ip route 192.168.100.0 255.255.255.0 serial 0/0.1
192.168.100.0 is the destination
serial 0/0.1 is the outgoing interface (instead of defining the IP address of the next-hop or next router).
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
Correct Answer by spremkumar about 9 years 11 months ago
In addition to Krisztian's reply you can even define the exit interface instead of mentioning the next hop ip address..
If the next hop is reachable via an ethernet interface you need to mention the exit interface followed by the next ip hop to reach the destination..
You can refer the below link fore more info and the options available with the command...
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124tcr/tiad_r/adressht.htm#wp1136518
regds
In static routes you have to give the destination network (192.168.100.0/24) and the next hop (where to forward this subnet) or the outgoing interface (serial 0). The routing table must contain the destination network and respective outgoing interface to be able to succesfully forward the particular network (and of course the outgoing interface must be up). In this case the 192.168.1.2 is the next hop address and actually this address is directly connected to serial 0 interface. So your router knows how to forward this network.
Anyway host B is not on the same subnet as with R2 ethernet 0.
Hope it helps,
Krisztian
Overall Rating: 5 (3 ratings)
Correct Answer
Hope it helps,
Krisztian
Correct Answer
spremkumar Mon, 06/11/2007 - 23:44
  • Red, 2250 points or more
regds
iifanatic Mon, 06/11/2007 - 23:58
Thanks.
One more question in addition to this query.
I have noticed that we can also give the address 0.0.0.0 or
255.255.255.255
What do all these addresses mean?
Say for instance I give the command:
ip route 0.0.0.0 255.255.255.0 192.168.1.2
I dont know if the above command is correct, but what will the 0.0.0.0 do here?
Similary with
ip route 255.255.255.255 255.255.255.0 192.168.1.2
mohammedmahmoud Mon, 06/11/2007 - 23:40
  • Green, 3000 points or more
Yes static routes must be manually configured all the path in both directions, the syntax is as follows:
ip route
From your example:
192.168.1.2 is the next-hop
Simply this states that to reach this destination go to the next-hop (next-router) with the following IP, or exit using the following outgoing interface if defined.
I hope that i've been informative, please never hesitate to ask further questions.
Mohammed Mahmoud.
iifanatic Tue, 06/12/2007 - 01:55
Thanks Mohammed
Would this command be also correct?
ip route 192.168.1.0 255.255.255.0 192.168.100.1
Now In the above command I am using the serial interface.
Correct Answer
mohammedmahmoud Tue, 06/12/2007 - 02:02
Mohammed Mahmoud.
s.arunkumar Tue, 06/12/2007 - 03:11
  • Bronze, 100 points or more
and something more...
if u are using next hop add.,then ur routing table will show entry for the route with "S" tag and via the next hop address,but if u are using exit interface then,the entry for the route will be with "S" tag,but as directly connected.(U can verify it using show ip route)
and more ...u can use both exit interface and next hop address in one command itself .
eg: ip route 192.168.100.0 255.255.255.0 se0/0 192.168.200.1
now the advantage here..
when next hop add. is used in static route cmd,a lookup will be done in routing able for next hop add.Specifying the exit interface avoids this as it is directly connected.But the disadvantage with exit interface is that ,it takes excessive b/w for arp lookups for all ip's on destination subnet.to avoid this both exit interface and next hop add can be specified,which minimize the routing lookup and also the arp need to resolve only for next hop add. ....hope i'amm not confusing.....
smothuku Tue, 06/12/2007 - 03:31
  • Silver, 250 points or more
Hi ,
Details about static route :
To establish static routes, use the ip route command in global configuration mode. To remove static routes, use the no form of this command.
ip route prefix mask {ip-address | interface-type interface-number [ip-address]} [dhcp] [distance] [name] [permanent | track number] [tag tag]
no ip route prefix mask
The establishment of a static route is appropriate when the Cisco IOS software cannot dynamically build a route to the destination.
When you specify a DHCP server to assign a static route, the interface type and number and administrative distance may be configured also.
If you specify an administrative distance, you are flagging a static route that can be overridden by dynamic information. For example, routes derived with Enhanced Interior Gateway Routing Protocol (EIGRP) have a default administrative distance of 100. To have a static route that would be overridden by an EIGRP dynamic route, specify an administrative distance greater than 100. Static routes have a default administrative distance of 1.
Static routes that point to an interface on a connected router will be advertised by way of Routing Information Protocol (RIP) and EIGRP regardless of whether redistribute static commands are specified for those routing protocols. This situation occurs because static routes that point to an interface are considered in the routing table to be connected and hence lose their static nature. Also, the target of the static route should be included in the network (DHCP) command. If this condition is not met, no dynamic routing protocol will advertise the route unless a redistribute static command is specified for these protocols. With the following configuration:
rtr1 (serial 172.16.188.1/30)--------------> rtr2(Fast Ethernet 172.31.1.1/30) ------>
router [rip | eigrp]
network 172.16.188.0
network 172.31.0.0
?RIP and EIGRP redistribute the route if the route is pointing to the Fast Ethernet interface:
ip route 172.16.188.252 255.255.255.252 FastEthernet0/0
RIP and EIGRP do not redistribute the route with the following ip route command because of the split horizon algorithm:
ip route 172.16.188.252 255.255.255.252 serial2/1
?EIGRP redistributes the route with both of the following commands:
With the Open Shortest Path First (OSPF) protocol, static routes that point to an interface are not advertised unless a redistribute static command is specified.
Adding a static route to an Ethernet or other broadcast interface (for example, ip route 0.0.0.0 0.0.0.0 Ethernet 1/2) will cause the route to be inserted into the routing table only when the interface is up. This configuration is not generally recommended. When the next hop of a static route points to an interface, the router considers each of the hosts within the range of the route to be directly connected through that interface, and therefore it will send Address Resolution Protocol (ARP) requests to any destination addresses that route through the static route.
The practical implication of configuring the ip route 0.0.0.0 0.0.0.0 ethernet 1/2 command is that the router will consider all of the destinations that the router does not know how to reach through some other route as directly connected to Ethernet interface 1/2. So the router will send an ARP request for each host for which it receives packets on this network segment. This configuration can cause high processor utilization and a large ARP cache (along with memory allocation failures). Configuring a default route or other static route that directs the router to forward packets for a large range of destinations to a connected broadcast network segment can cause your router to reload.
Specifying a numerical next hop that is on a directly connected interface will prevent the router from using proxy ARP. However, if the interface with the next hop goes down and the numerical next hop can be reached through a recursive route, you may specify both the next hop and interface (for example, ip route 0.0.0.0 0.0.0.0 ethernet 1/2 10.1.2.3) with a static route to prevent routes from passing through an unintended interface.
The track number keyword and argument combination specifies that the static route will be installed only if the state of the configured track object is up.
Examples
The following example chooses an administrative distance of 110. In this case, packets for network 10.0.0.0 will be routed to a router at 172.31.3.4 if dynamic information with an administrative distance less than 110 is not available.
ip route 10.0.0.0 255.0.0.0 172.31.3.4 110
Note Specifying the next hop without specifying an interface when configuring a static route can cause traffic to pass through an unintended interface if the default interface goes down.
The following example routes packets for network 172.31.0.0 to a router at 172.31.6.6:
ip route 172.31.0.0 255.255.0.0 172.31.6.6
The following example routes packets for network 192.168.1.0 directly to the next hop at 10.1.2.3. If the interface goes down, this route is removed from the routing table and will not be restored unless the interface comes back up.
ip route 192.168.1.0 255.255.0.0 Ethernet 0 10.1.2.3
Satish
