BAT application --> Subscriber Install
Jun 11th, 2007
It seems that my Bat 5.2.3 has some trouble on my CCM publisher. When importing files, I got an error "Error Number : -2146827850 Description : Object doesn't support this property or Method"
Cool very clear error message.
my question is simple, may I install the Bat application on the subscriber ?
Is it still the Main Database which will be provisionned by the Bat application ?
kind regards
rob.huffman Tue, 06/12/2007 - 04:24
Hi Frederic,
BAT has to be installed on the Publisher. Here is a clip from the installation doc;
"You must install BAT on the same server as the publisher database for Cisco Unified CallManager."
From this doc;
Bulk Administration Tool User Guide, Release 5.2(3)
Installing the BAT Application
Hope this helps! I have read others having problems with BAT sometimes did Uninstall/Install to solve these errors.
