Error Updating Locale
Jun 12th, 2007
I've got a problem with a number of 7961G phones in that the above message is logged in system messages on the handsets. Copy of log file is:-
15:30:14 Error Updating Locale
15:30:13 SEP001BD40B9E30.cnf.xml
15:30:13 No CTL installed
15:30:13 File Not Found : CTLFile.tlv
15:30:13 No DNS Server IP
Config is attached - any idea's please?
Thanks in advance.
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Tue, 06/12/2007 - 02:42
  • Hall of Fame,
    Founding Member
in short, you can ignore all these errors.
The updating locale is due to certain files that the phone looks for when it boots. If you do "term mon" and "debug tftp events" you will see them. You can download the "locale package" from CCO and copy them on the router. Then configure "tftp-server ... alias ..." to have them load by the phone.
The no DNS server ip is due to lack of dns server in your dhcp definition for the phones, but we know that dns for the phones is usually unnecessary.
Paolo Bevilacqua Fri, 07/13/2007 - 01:31
  • Hall of Fame,
    Founding Member
Unfortunately, as far as I know, there are no released localization files for SIP.
You can try downloading the the localization files for SCCP, alias the files via tftp-command however when I tried that, I did not succeed at changing the language on SIP phones.
