Need help on CCM upgrade.
Jun 12th, 2007
Overall Rating: 5 (1 ratings)
espereir Tue, 06/12/2007 - 21:07
  • Silver, 250 points or more
Hello Esa,
Did you noticed that you have posted the same question 3 times? Anyhow, AD 2K and 2K3 are supported for the AD integration; the problem will be if the Windows AD upgrade changes some settings like the Schema or some CCM IPT attributes or objects, my advise will be to run the AD integration again after the Windows upgrade, just in case something is changed on AD. Please follow the instructions on this link in order to check run the AD plugin.
http://cisco.com/en/US/partner/products/sw/voicesw/ps556/products_tech_note09186a0080094493.shtml
Please let us now how it goes!!!
esa786_2 Tue, 06/12/2007 - 21:19
Thank you for your reply. I will let you know result.
thanks
esa
