Unity Express voiceview host not found
Jun 12th, 2007
Hi, i have unity express 2.3.4 and callmanager express 4, when i hit the services button on my 7961's it says host not found, and i cant connect to voiceview. i have configured as recommended:
Callmanager Express:
no ip domain lookup
ip domain name ********removed****.com
ip ssh version 2
interface FastEthernet0/1
no ip address
no ip unreachables
no ip proxy-arp
duplex full
speed 100
interface FastEthernet0/1.2
description <<PHONE_VLAN>>
encapsulation dot1Q 2
no ip proxy-arp
ip nat inside
ip virtual-reassembly
service-policy output output-L3-to-L2
interface FastEthernet0/1.3
description <<DATA_VLAN>>
encapsulation dot1Q 3
ip address 10.0.0.220 255.255.255.0
interface Service-Engine1/0
ip unnumbered FastEthernet0/1.2
service-module ip address 192.168.1.2 255.255.255.0
service-module ip default-gateway 192.168.1.1
ip route 192.168.1.2 255.255.255.255 Service-Engine1/0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
ip http path flash:
ip nat inside source route-map NONAT interface FastEthernet0/0 overload
tftp-server flash:P00307020200.bin
tftp-server flash:P00307020200.loads
tftp-server flash:P00307020200.sb2
tftp-server flash:P00307020200.sbn
tftp-server flash:P00403020214.bin
tftp-server flash:TERM70.7-0-3-0S.loads
tftp-server flash:term70.default.loads
tftp-server flash:term71.default.loads
tftp-server flash:CVM70.2-0-2-26.sbn
tftp-server flash:cnu70.2-7-6-26.sbn
tftp-server flash:Jar70.2-9-2-26.sbn
tftp-server flash:S00103020002.bin
tftp-server flash:P00503010100.bin
tftp-server flash:cmterm_7936.3-3-5-0.bin
tftp-server flash:CP7905060000SCCP050124A.sbin
tftp-server flash:CP7912060000SCCP050124A.sbin
tftp-server flash:music-on-hold.au
tftp-server flash:cmterm_7920.4.0-02-00.bin
tftp-server flash:Jar41sccp.8-2-2ES1.sbn
tftp-server flash:cnu41.8-2-2ES1.sbn
tftp-server flash:apps41.8-2-2ES1.sbn
tftp-server flash:dsp41.8-2-2ES1.sbn
tftp-server flash:cvm41sccp.8-2-2ES1.sbn
tftp-server flash:SCCP41.8-2-2SR1S.loads
tftp-server flash:term41.default.loads
tftp-server flash:term61.default.loads
tftp-server flash:P0030702T023.bin
tftp-server flash:P0030702T023.loads
tftp-server flash:P0030702T023.sb2
tftp-server flash:P0030702T023.sbn
tftp-server flash:en-tc-sccp.jar
tftp-server flash:en-mk-sccp.jar
tftp-server flash:en-td-sccp.jar
tftp-server flash:g3-tones.xml
tftp-server flash:S00105000200.sbn
control-plane
telephony-service
max-ephones 36
max-dn 64
ip source-address 192.168.1.1 port 2000
caller-id block code *1470
calling-number initiator
url services http://192.168.1.2/voiceview/common/login.do
url authentication http://192.168.1.2/voiceview/authentication/authenticate.do
network-locale GB
time-format 24
date-format dd-mm-yy
voicemail 600
max-conferences 8 gain -6
call-forward pattern .T
moh music-on-hold.au
web admin system name sysadmin password cisco
web admin customer name Customer password moorfield
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
login timeout 15 clear 00:15
directory last-name-first
create cnf-files version-stamp 7960 Jun 11 2007 14:38:25
line con 0
line aux 0
line 66
no activation-character
no exec
transport preferred none
transport input all
transport output all
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
webvpn context Default_context
ssl authenticate verify all
no inservice
end
Any one know of how to debug this, ?
rhockley Tue, 06/19/2007 - 17:47
I get the same problem, however if I plug in a 7940 or 7960 it works fine, I beleive the problem is with the 41/61 phone loads.
