06-12-2007 02:07 AM
Hi to all!
I'm trying to open Campus Manger home page from LMS 2.6 suite.
It doesn't open (staus bar stop at the half)
I checked the ANIServer process by pdshow command:
C:\tools\>pdshow ANIServer
Process= ANIServer
State = Running with busy flag set
Pid = 15396
RC = 0
Signo = 0
Start = 12/06/2007 11.55.14
Stop = Not applicable
Core = Not applicable
Info = ANIServer started.
Waht is this "flag"?
From the log seems that it doesn't connect to the database
ani.log
2007/06/12 11:55:28 main ani MESSAGE DBConnection: Created new Database connection [hashCode = 4565987]
2007/06/12 11:55:28 main ani MESSAGE DBConnection: Closed Database connection [hashCode = 4565987]
log4j:ERROR No appenders could be found for category (CTM.common).
log4j:ERROR Please initialize the log4j system properly.
new instance of Ptdm create
new appId created
new appId created
Common trust user is: admin
User name in Security context is: admin
Nothing to decrypt
Nothing to decrypt
Nothing to decrypt
Nothing to decrypt
2007/06/12 11:56:45 DBConnecton-Reaper ani MESSAGE DBConnection: Closed Database connection [hashCode = 977702]
2007/06/12 11:56:45 DBConnecton-Reaper ani MESSAGE DBConnection: Closed Database connection [hashCode = 2191491]
How I can debug?
Thanks!
Leonardo
06-12-2007 04:58 AM
ANIServer is working fine based on this output. All of these messages are typical. The problem must be with your client, or the connection between the client and server. Check the Java Plug-in console for any errors, and make sure you are using the supported version of the Java Plug-in. For LMS 2.6, that is either 1.4.2_10 or 1.4.2_12 (if you have the recent DST patch applied).
Finally, check to see if there are any firewalls or proxies between your client and server. You must disable all proxying in the Java control panel. You must also allow all TCP port 1683, 1684, and 8088 traffic between client and server.
06-12-2007 05:44 AM
It just occurred to me you said, "Campus home page." I saw status bar, and I thought the progress bar you get when opening Topology Services. You don't need to bother with the Java Plug-in stuff in that case. The most likely cause of the Home page freezing is a large number of User Tracking report jobs. Purging those completed jobs can help improve Home page load times.
You should also check the NMSROOT/MDC/tomcat/logs/stdout.log for errors.
