Unable to access console port
Jun 12th, 2007
i was unable to access my cat6509 neither from console port or telnet access since someone by mistake has modified the setting in the switch &now it become inaccessible so is there any suggestion to workaround without losing my current configuration .
by the way when i connect to the concole port through terminal window nothing can by display in the terminal(blank)
guruprasadr Tue, 06/12/2007 - 03:34
Can you able to Ping the IP Address of the Switch ? ?
Try to reach switch via different VLAN router IP / different Fast Ethernet Port.
Else you need to reboot & activate the switch.
Pls Rate if Helps
Best Regards,
Guru Prasad R
engraed96 Tue, 06/12/2007 - 03:42
actualy i can't be able to ping to the switch since the ip are not known to us !only we can access to the MSFC .so i need to access the blocked consoll port to fix the problems but i can't
mohammedmahmoud Tue, 06/12/2007 - 04:40
I agree with Andrea, how do you have access to the MSFC ? and if so then what is your problem, are you running Native or Hybrid mode ?
Mohammed Mahmoud.
satish_zanjurne Thu, 06/14/2007 - 10:22
If you can see this CAT 6509 device in CDP neighbor details in the neighboring Cisco Device...you will get IP of CAT 6509..which will be helpful..
