Stable IOS for 3640
Jun 12th, 2007
I have 3640 router with 12.3(8) T8 IOS.
have configured E1 card for VoIP.
I have problem that when 20 -30 agents get logged in the CPU utilization of router goes beyond 50%.have cleared all debug and accounting command.
Any suggestion on IOS.
or any other solution.
Paolo Bevilacqua Tue, 06/12/2007 - 03:25
the 3640 is not so powerful and the utilization may be normal. If you do "show proc cpu" you will see what is taking cpu.
la-technologies Tue, 06/12/2007 - 03:32
When i issue the "show proc cpu" it does not show any process that is taking more % utilization.
Max any process such as "IP input" and "AFSapp1" takes not more than 4%.
Paolo Bevilacqua Tue, 06/12/2007 - 04:01
Then if no process has abnormal CPU you have to live with it or upgrade to a faster router.
