PoE for Cisco 1242AG and 1310G Access Points
Jun 12th, 2007
Dear All,
we purchased a Cisco 1242AG and a 1310G Access Point and in the DataSheet it was specified that these APs support Power-over-Ethernet. The problem is we don't see any RJ-45 port in either AP which could be used for connecting the AP to an PoE Switch. Can you please tell us how we can connect these APs to an 802.11af compatible PowerBridge (by Intermec) ? Thanks.
Overall Rating: 4 (1 ratings)
Rob Huffman Tue, 06/12/2007 - 04:43
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Thorsten,
The 1242 should be good to go but the 1310 is powered quite differently. Have a look;
AP 1240 Series - Hardware (see diagram)
http://www.cisco.com/en/US/products/ps6521/products_installation_guide_chapter09186a008079b7f4.html#wp1071972
Connecting the Ethernet and Power Cables
http://www.cisco.com/en/US/products/ps6521/products_installation_guide_chapter09186a008079b7f4.html#wp1052781
1300 Series Power
Power
The access point/bridge receives inline power from the Cisco Aironet Power Injector (hereafter called the power injector). Dual-coax cables are used to provide Ethernet data and power from the power injector to the access point/bridge. The power injector is an external unit designed for operation in a sheltered environment, such as inside a building or vehicle. The power injector also functions as an Ethernet repeater by connecting to a Category 5 LAN backbone and using the dual-coax cable interface to the access point/bridge.
The power injector is available in two models:
Cisco Aironet Power Injector LR2 standard version (included with the access point/bridge)
48-VDC input power
Uses the 48-VDC power module (included with the access point/bridge)
Cisco Aironet Power Injector LR2T optional transportation version
12- to 40-VDC input power
Note The power injector and the power module must not be placed in an outdoor unprotected environment. The power module must not be placed in a building's environmental air space, such as above a suspended ceiling.
http://www.cisco.com/en/US/products/ps5861/products_installation_guide_chapter09186a008079b93b.html#wp1051840
Dual coaxial cable to run from the power injector to the 1300. See attached notes:
Cisco Aironet 1300 Series
Cisco Aironet 1300 Series Access Point/Bridge Power Injector
The Cisco Aironet 1300 Series Outdoor Access Point/Bridge Power Injector,converts the standard 10/100 BaseT Ethernet interface that is suitable for weather protected areas to a dual F-Type connector interface for coax cables that are more suitable for harsh outdoor environments. The Power Injector also provides power to the outdoor unit over the same cables with a power discover feature and surge protection. To support longer cable runs from your wireless network switch or router, the Power Injector LR is designed to accommodate up to a 100 meter coaxial cable run plus 100 meters of indoor cat5 cable?enabling total cable runs up to 200 meters. The Cisco Aironet 1300 Series Outdoor Access Point/Bridge ships with the Power Injector LR2 and an AC power supply.
From this link:
http://www.cisco.com/en/US/products/ps5861/products_data_sheet09186a008022551d.html
Cisco Aironet 1300 Series Outdoor Access Point/Bridge Hardware Installation Guide
Ethernet Ports
The access point/bridge dual-coax Ethernet ports consists of a pair of 75-ohm F-type connectors, linking the unit to your 100BASE-T Ethernet LAN through the power injector. The dual-coax cables are used to send and receive Ethernet data and to supply inline 48-VDC power from the power injector to the access point/bridge.
From this link:
http://www.cisco.com/en/US/products/ps5861/products_installation_guide_book09186a00804d3095.html
AIR-PWRINJ-BLR2
F-Type Connectors
Dual coaxial cable carries full-duplex Ethernet, DC power, and full-duplex console port (RS-232 connection)
From this link:
http://www.cisco.com/en/US/products/ps5861/products_data_sheet09186a00802252e1.html
Hope this helps!
Rob
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
