CME 4.1 - Transfer calls to outside numbers
Jun 12th, 2007
When receiving a call on an IP phone it is not possible to tranfer it to an outside number, only to inside numbers. What should I do to fix this?
paolo bevilacqua Tue, 06/12/2007 - 03:58
  • Hall of Fame,
    Founding Member
As I was telling you in the other thread, check what you have as "transfer-pattern" under "telephony-service". You can have multiple patterns, if you want transfer to external, must include the digit you dial for external access.
paolo bevilacqua Tue, 06/12/2007 - 05:45
  • Hall of Fame,
    Founding Member
Glad to know it worked. Would you consider rating useful posts using the scrollbox below?
Good luck!
