CallerInfo
Answered Question
Jun 12th, 2007
I want to try to add the CallerInfo Service.
The lookup to the Ldap server can be done for all phones of the user (mobile, other phones, other mobiles, etc), as we did for corparate directory?
Correct Answer by stephan.steiner about 9 years 7 months ago
Yes it most certainly can. I have a highly advanced version of this application that does LDAP, Exchange and Internet lookup requests.
Hopefully your corporate directory is jsp based so you have inhouse knowledge on how to extend te ldap lookup classes in the SDK.
Overall Rating: 5 (1 ratings)
Correct Answer
stephan.steiner Tue, 06/12/2007 - 23:32
giovannicorduas Wed, 06/13/2007 - 09:14
Thanks. I'll try to install and customize the application.
It's very interesting your extension to the Exchange contacts.
regards
andrewjuliz Fri, 07/13/2007 - 01:11
May I get the application? I interested to get contact from my exchange contact folder. Thank you.
stephan.steiner Tue, 07/17/2007 - 04:19
Well.. you can have it if you pay for it. Seeing the amount of support required for installation and operation, we've only sold it to our regular voice customers (I work for a solution provider, not a software company) where support is handled as part of maintenance contracts and where we already have access to the voice systems.
If you want free, head over to myvoipsource.ch, they have a bunch of interesting applications. You'll soon notice it's not all setup.exe either ;)
