Not able to configure SSH
Answered Question
Jun 12th, 2007
I'm using 1841 router.My question is I'm not able to configure SSH in this router ,Any IOS problem?
Sh version
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(1c), RELEASE SO
FTWARE (fc1)
Correct Answer by spremkumar about 9 years 4 months ago
Hi Karthick
You are currently running IP BASE Feature Set ios on your router you need to upgrade the same to Advanced Security Services or SP Services Feature set to have SSH support in your router..
Overall Rating: 5 (1 ratings)
PAUL TRIVINO Tue, 06/12/2007 - 15:51
You *probably* need to generate the keys - try
crypto key generate rsa
It will ask how long a key, use at least 1024 for most ssh clients.
When you're done it will say "ssh 1.99 enabled" or something.
Oops! Just noticed your sh ver - I don't think IPBASE doe it, you need IP with crypto.
mkarthick Tue, 06/12/2007 - 19:55
Hi Paul,
Thanks for your reply
Should i upgrade my IOS? could u plz explain to me .
