3560/3750 Enhanced Image PBR Performance
Jun 12th, 2007
Does anyone have an idea of the PBR performance of a 3560 or 3750 switch which using an EMI image? How many pps is it likely to handle?
Other than PBR, it will be static routing, with nothing CPU intensive running
Overall Rating: 2 (1 ratings)
Amit Singh Tue, 06/12/2007 - 07:25
Here is what it depends upon:
You can define a maximum of 246 IP policy route maps on the switch stack.
You can define a maximum of 512 access control entries (ACEs) for PBR on the switch stack.
The number of TCAM entries used by PBR depends on the route map itself, the ACLs used, and the order of the ACLs and route-map entries.
HTH,Please rate if it does.
-amit singh
ericgarnel Tue, 06/12/2007 - 07:38
I tried this a while back, but moved the PBR functionality over to a pair of 3845 routers. I am doing ip sla & nbar on the routers as well.
The 3845s seem to function better for this stuff as well as have better support for monitoring stuff like ip sla & nbar. I guess this is also true of IOS routers vs switches in general.
farkascsgy Tue, 06/12/2007 - 10:32
I used PBR on 3750, but the performabce was very bad. Unfortunately I can't tell pps and other datas, but when we trasfer files from file server the performance wasn't acceptable - transmission rate was ~ 50% worst than without PBR and also the CPU usage was 80%.
So finally I eliminated the PBR, what I used only for default routes....
Please rate me if I helped.
