Selftest info
Jun 12th, 2007
my UT application doesn't add nor delete records to the database and I'm wondering whether it may have to do with some of the following errors found running a selftest.
ERROR: pkgchk CSCOcmani failed.
ERROR: /opt/CSCOpx/backup/manifest/campus/database/ani.txt permissions <0640> expected <0750> actual
ERROR: pkgchk CSCOmd failed.
ERROR: /tmp/.SQLAnywhere permissions <0770> expected <0777> actual
Joe Clarke Tue, 06/12/2007 - 06:45
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No, these errors have nothing to do with the problem you describe. To debug UT problems finding MAC addresses, you should enable vmpsadmin debugging under Campus Manager > Admin > Campus Data Collection > Debugging Options, then run a new UT acquisition. Check the ut.log for errors.
Debugging problems removing entries is a bit more complicated, and you should work with the TAC to enable debugging there.
