Netflow on a 6503
Jun 12th, 2007
I have a customer who has an existing 6503 in place, and they are interested in turning on Netflow. I do not believe they are licensed to run it. Here is a show versions if that helps any:
echnical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Sat 08-Jul-06 03:13 by kellythw
Image text-base: 0x40101040, data-base: 0x42D88000
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(18)SXF5
, RELEASE SOFTWARE (fc3)
OWHB_6503_1 uptime is 7 weeks, 6 hours, 54 minutes
Time since OWHB_6503_1 switched to active is 7 weeks, 6 hours, 54 minutes
System returned to ROM by power cycle (SP by power on)
System restarted at 02:49:29 extended_DST Wed Apr 11 2007
System image file is "sup-bootdisk:s72033-ipservicesk9_wan-mz.122-18.SXF5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C6503-E (R7000) processor (revision 1.3) with 458720K/65536K bytes of m
emory.
Processor board ID FOX10021594
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
SuperLAT software (copyright 1990 by Meridian Technology Corp).
X.25 software, Version 3.0.0.
Bridging software.
TN3270 Emulation software.
29 Virtual Ethernet/IEEE 802.3 interfaces
74 Gigabit Ethernet/IEEE 802.3 interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Does anyone have any idea the minimum IOS or licensing I need to have them purchase in order to get them the ability to turn on Netflow?
Thank you.
T
Amit Singh Tue, 06/12/2007 - 07:40
T,
You have Sup 720 and it supports Netflow on it. However,You would need to have a Cisco Netflow collector application that is running either on a Linux/Solaris server.
Informations data is avaialble and collected by
netflow but for doing the bandwidth analysis and/or reporting you will need Cisco Netflow collector application or 3rd Party netflow analayzer.
Cisco has Network Analaysis Module for Cat6500 for netflow accouting.The NAM has independent backplane interfaces for SPAN/VACL traffic and for NetFlow. The NAM uses the collected packets to provide information on applications, hosts, conversations, etc.
Enabling Netflow:
http://www.cisco.com/univercd/cc/td/doc/cisintwk/intsolns/netflsol/nfwhite.htm#xtocid2867938
Page for NAM:
http://www.cisco.com/en/US/products/sw/cscowork/ps5401/index.html
http://www.cisco.com/en/US/products/hw/switches/ps708/products_data_sheet0900aecd804bab11.html
HTH,Please rate if it does.
-amit singh
fiene3606 Tue, 06/12/2007 - 07:46
Amit,
So based on what you see, there are no additional licenses or higher IOS level that they need to buy or upgrade to? I know the software looks like it supports it, but based on what you see, as long as they have a collector, which they do, they can just turn Netflow on on this device?
Richard Burts Tue, 06/12/2007 - 08:32
Tyler
They should be able to just turn on Netflow. There are no additional licensing requirements to run Netflow on the 6500.
Rick
Marco Hornung Sat, 06/16/2007 - 11:04
I have only this command:
6509(config)#ip flow export ?
layer2-switched layer2 switched flow
I can?t use ip flow-export destination x.x.x.x 9995
why?
We use sup720
