FXO SNMP
Answered Question
Can I reset an FXO using SNMP MIB?
Correct Answer by paolo bevilacqua about 9 years 10 months ago
Yes.
From the CISCO-VOICE-ANALOG-IF-MIB:
-- The ifEntry for an Analog Voice Interface supports the
-- ifGeneralInformationGroup of Cisco IF-MIB.
Hence if you change the IfAdminStatus from up to down to up again, you will have reset the voice port.
Note, that if the FXO port got stuck because of a software bug, the above operation doesn't guarantte it will resume working.
Overall Rating: 5 (2 ratings)
Correct Answer
paolo bevilacqua Tue, 06/12/2007 - 08:03
  • Hall of Fame,
    Founding Member
Yes.
paolo bevilacqua Tue, 06/12/2007 - 08:31
  • Hall of Fame,
    Founding Member
You need a network management platform, insert the right OID as indicated by the MIB for the right interface, change status to down and up again. The details of operation depends on the network management platform used.
I use this method and works...
Index of FXO
snmpwalk -c public -m CISCO-VOICE-ANALOG-IF-MIB.txt 192.168.0.100 .1.3.6.1.4.1.9.9.62.1.3.2.1.1
.iso.3.6.1.4.1.9.9.62.1.3.2.1.1.3 = 1
.iso.3.6.1.4.1.9.9.62.1.3.2.1.1.4 = 1
.iso.3.6.1.4.1.9.9.62.1.3.2.1.1.5 = 1
.iso.3.6.1.4.1.9.9.62.1.3.2.1.1.6 = 1
Down the FXO
snmpset -c public -m CISCO-VOICE-ANALOG-IF-MIB.txt 192.168.0.100 .1.3.6.1.2.1.2.2.1.7.3 i 2
UP de FXO
snmpset -c public -m CISCO-VOICE-ANALOG-IF-MIB.txt 192.168.0.100 .1.3.6.1.2.1.2.2.1.7.3 i 1
Thanks for your time.
paolo bevilacqua Fri, 06/15/2007 - 07:25
  • Hall of Fame,
    Founding Member
Glad to know it worked, thanks for the nice rating and good luck!
