port security duplicate mac address
Jun 12th, 2007
hi lads ,
wea re using port security with a maximum of 10 mac-addresses specified . WE are also using the sticky feature to aid the configuration. Everything is on one vlan in the organisation. Heres the problem when we take a laptop from a port int a different departmetent up to the I.T department and plug it into one of our ports , it doesn't work . The new port dosent go into an err-disable state and if we try to speific the mac address on the new port port we get "Mac address already exists . The mac-add is under the old port , when we remove the entry fom the old port it works any ideas . 3750 stack running 12.2(25) SEB4.
Thanks in advance.
Kevin
cisco_lad2004 Tue, 06/12/2007 - 12:01
  • Gold, 750 points or more
Kevin
check teh config of the 1stswitch and check if teh mac address has been added to it. this is what "port-security mac-address sticky" and if it is the case, of course you will have a duplicate mac-address.
to remove it, use "no switchport port-security mac-address mac-address" this should clear your issue.
Sam
kcornally Wed, 06/13/2007 - 03:24
hi lads
thanks for the replies.
Yes I have speficed a time and action but the mac address stays ubder the original port but when I do a sh mac-address table xxxxx.xxxx.xxxx the mac address is no longer mapped to any port . The new port still passes no traffic.
kcornally Wed, 06/13/2007 - 04:26
here is the configuration as you can see the time and aging action have been specifed but it dosent work. Is there something we are missing here or is this a possible issue with the cam table and aging mac addresses timer on the interface .
Any ideas would be great....
interface FastEthernet4/0/27
switchport mode access
switchport port-security maximum 10
switchport port-security aging time 6
switchport port-security aging type inactivity
switchport port-security mac-address sticky
switchport port-security aging static
switchport port-security mac-address sticky 000b.cdf7.2748
switchport port-security mac-address sticky 0012.79be.d781
switchport port-security mac-address sticky 0015.60bb.a189
switchport port-security mac-address sticky 00b0.d018.0034
switchport port-security mac-address sticky 00c0.9f76.7e83
switchport port-security mac-address sticky 00c0.9f76.7ea5
spanning-tree portfast
spanning-tree bpduguard enable
kcornally Wed, 06/13/2007 - 05:33
also I noticed that under the remaining time in the age colum under the show port-security
is set ot a - sign , it should give a relevant number as time decreases instead its stuck at - .
Again any idea would be great.
Edison Ortiz Wed, 06/13/2007 - 05:39
  • Hall of Fame,
    Founding Member
Do you shutdown the laptop before taking it to a new port at the other location ?
kcornally Wed, 06/13/2007 - 05:52
thanks for all the posts lads,
I believe I've figured it out , you dont appear to be able to use the sticky command under the interface and also the aging-time .
When the sticky command is removed the time out works fine , although you can type in both commands the timeout will never work because the sticky command copies the mac address to the config .
Edison Ortiz Wed, 06/13/2007 - 06:02
  • Hall of Fame,
    Founding Member
Ah, so one of the mac-address listed above was the laptop's ? Well, yeah, you are statically associating that mac-address to the port.
cisco_lad2004 Wed, 06/13/2007 - 07:58
once u have removed ur PC, use teh above then recheck if mac address is still part of the config...it shoudl not be there anymore which means no duplication.
