VPN trouble between 2 501's after IP address update
ciscodest83
We have a VPN set up between 2 Cisco 501 Pix's. The internet provider at one of our sites changed our static IP address. I updated the IP address on the affected pix, and updated the IP references on the other PIX, but I still can't get the VPN tunnel to re-establish. Here are the configs:
The one that I had to change the IP on:
Pix1# sho run
: Saved
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxx
passwd xxx
hostname xxx
domain-name xxx
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
name 66.x.x.29 xxx
access-list vpnnat permit ip 192.168.2.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list inside_acl permit ip any any
access-list inside_acl permit icmp any any
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 66.x.x.x.255.255.0
ip address inside 192.168.2.249 255.255.255.0
ip audit info action alarm
ip audit attack action reset
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list vpnnat
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
access-group inside_acl in interface inside
conduit permit icmp any any
route outside 0.0.0.0 0.0.0.0 66.76.177.1 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
sysopt connection permit-pptp
crypto ipsec transform-set strong esp-3des esp-md5-hmac
crypto map mymap 10 ipsec-isakmp
crypto map mymap 10 match address vpnnat
crypto map mymap 10 set peer Brownwood
crypto map mymap 10 set transform-set strong
crypto map mymap 10 set security-association lifetime seconds 3600 kilobytes 4608000
crypto map mymap interface outside
isakmp enable outside
isakmp key ******** address Brownwood netmask 255.255.255.255
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 28800
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh 192.168.2.0 255.255.255.0 inside
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 60
console timeout 0
dhcpd address 192.168.2.10-192.168.2.30 inside
dhcpd dns 208.180.42.68 208.180.42.100
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
username admin password xxxencrypted privilege 2
username rlance password xxx encrypted privilege 15
terminal width 80
banner exec
ciscodest83
the other PIX:
Pix2(config)# sho run
: Saved
PIX Version 6.3(5)
enable password xxx
passwd xxx
hostname Brownwood
domain-name Heartland
names
name 66.76.177.32 SanAngelo
access-list vpnnat permit ip 192.168.1.0 255.255.255.0 192.168.2.0 255.255.255.0
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 66.x.x.29 255.255.255.128
ip address inside 192.168.1.249 255.255.255.0
ip verify reverse-path interface outside
ip verify reverse-path interface inside
pdm history enable
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 66.15.222.1 1
aaa authentication ssh console LOCAL
http 192.168.1.0 255.255.255.0 inside
floodguard enable
crypto map mymap 10 set peer SanAngelo
isakmp key ******** address SanAngelo netmask 255.255.255.255
isakmp keepalive 10
telnet timeout 5
ssh 0.0.0.0 255.255.255.255 outside
ssh 192.168.1.0 255.255.255.0 inside
ssh timeout 60
console timeout 0
dhcpd address 192.168.1.10-192.168.1.30 inside
dhcpd lease 3600
dhcpd enable inside
terminal width 80
Is there anything there that I'm missing? I didn't initially configure these, and I'm stumped as to why, after updating the IP's on both sides, I no longer have a connection. Thanks!
You may have to re-enter the command
"isakmp enable outside"
