fmeetz Tue, 06/19/2007 - 03:42
  • Bronze, 100 points or more
Yes we could use COR to restrict the calls.
j.mccartney Tue, 06/19/2007 - 05:36
Do you have a cfg I could look at to get an idea.
Thanks.
j.mccartney Tue, 07/10/2007 - 05:33
Thanks for the information, I think I have configured the solution I was looking for. Does anyone know if there is a way to assign DN's from CCM through the VG224 and have it go out thru POTS lines? Right now it appears they are going out the PRI's we have.
Right now I have cfg'd the VG to use MGCP through partitions/CSS to block inbound calls and allow outbound only.
Thanks again to all.
