AD - ACS Group Mappings
Jun 12th, 2007
I have created a group on ACS and used:
Ext User Database > Ext Grp Mappings to create mapping b/w ACS Group and AD Group. This works fine on Primary. However this information is not replicated to secondary. Would I have to recreate group mappings on each ACS Server (Primary and Backup and possibly another Backup). Is there a workaround or a more elegant method?
Overall Rating: 4 (1 ratings)
Jagdeep Gambhir Tue, 06/12/2007 - 09:58
  • Red, 2250 points or more
The following items cannot be replicated:
IP pool definitions (for more information, see About IP Pools Server).
ACS certificate and private key files.
Unknown user group mapping configuration.
Dynamically-mapped users.
Settings on the ACS Service Management page in the System Configuration section.
RDBMS Synchronization settings.
Third-party software, such as Novell Requestor or RSA ACE client software.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/acs40/user/sad.htm#wp756078
Hope that helps !
Jagdeep
