Using ASDM with ASA5540 on Transparent Mode
Jun 12th, 2007
Is there a way I can manage and configure the ASA5540 using ASDM v5.0 when I change it to transparent mode?
I CLI to the ASA5540 and change it to transparent mode, then I added an IP address to the device with the same subnet where it is connected to the 6509, and I configure G0/0 and G0/1 with their corresponding security levels and issue a no shut, including m0/0. After this, I can't connect to it anymore using the ASDM software.
vitripat Tue, 06/12/2007 - 09:58
You should be able to connect to ASDM using the management IP address. Please make sure you have all the necessary commands to allow ASDM access to the respective interfaces.
Vibhor.
pabblitto1 Wed, 06/13/2007 - 07:22
Thanks Vibhor. I got it to work on the Transparent mode by adding the http , adding the security level to the interfaces, and adding a name to the interfaces.
-Paul
