06-12-2007 10:17 AM - edited 03-11-2019 03:28 AM
hi, what's License Requirements to do failover between two 6513 with FWSM module
THANKS
Solved! Go to Solution.
06-12-2007 10:59 PM
Can you be a bit more specific. If you have an FWSM in each 6513 chassis you should be able to do failover by default with whatever license you have.
Jon
06-12-2007 10:59 PM
Jon
06-13-2007 01:06 AM
hi , thanks for you response
i have two FWSM in each 6513 chassis,and i want to failover , so it's possible ?
06-13-2007 01:20 AM
Yes inter chasis failover is possible
Please consult this URL:
M.
06-13-2007 02:14 AM
thanks
what about intra chassis failover , can i do it without failover licence ( i have fwsm in each 6513 and i run 3.1 version )
06-13-2007 01:21 AM
Yes it's possible. You don't say which version of software you are running but attached is a link to FWSM 3.1 configuration. You want the intra-chassis failover section.
Jon
