Problem with router Cisco 1700 and HP J4900A ProCurve Switch 2626
Jun 12th, 2007
Hi, first of all, sorry for my inglish :)
I have two router Cisco 1700 with HSRP and load balancing enabled, and 3 HP J4900A ProCurve 2626 switches, each router Cisco is pluged to a diferent swicth.
Problem is that sometimes it starts lossing packets. When i do pings to the lan ip of booth routers i also losse packets, even if i am doing ping in the same network where the routers are. The only way to get things work again is rebooting the switches.
any ideas of whats going on? or possible things to check?
jasonrandolph Tue, 06/12/2007 - 13:04
Hard set the speed/duplex of the routers and the switch if you can to 100/full.
