PIX, Object-Groups & Port Range Forwarding
Can anyone tell me why the following would not work through a pix 525? I have two remote offices trying to connect back with a VoIP phone system. We are forwarding all traffic on a ouside IP (xxx.xxx.xxx.152) address to an internal IP (xxx.xxx.xxx.12) and defined the following ACL's/Statics.
object-group network Some_NetGroup_1
description Some Remote Offices
network-object xxx.xxx.xxx.14 255.255.255.255
network-object xxx.xxx.xxx.22 255.255.255.255
object-group service Some_Group_TCP tcp
port-object eq xxxx
port-object eq xxxx
port-object eq xxxx
object-group service Some_Group_UDP udp
port-object eq xxxx
port-object range xxxx xxxx
access-list outside_in extended permit tcp object-group Some_NetGroup_1 host xxx.xxx.xxx.152 object-group Some_Group_TCP
access-list outside_in extended permit udp object-group Some_NetGroup_1 host xxx.xxx.xxx.152 object-group Some_Group_UDP
static (inside,outside) xxx.xxx.xxx.152 xxx.xxx.xxx.12 netmask 255.255.255.255
Thank you for any suggestions.
Drew
Jon Marshall Tue, 06/12/2007 - 22:57
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Well the config looks okay. Does the expanded access-list look right when you do a "sh access-list outside_in"
You don't include the statement but i'm assuming you have applied the access-list to your outside interface ie.
access-group outside_in in interface outside
If you have applied this then are you sure you have all the ports covered. What if you temporarily allow all IP from one of the remote addresses, does it then work ?
Jon
