Network Security
Engage with peers and experts on network security topics such as FTD, FMC, FDM, CDO and ASA.
Cisco CyberSecurity
Labels
hello We have a old fire power that I have no idea how to upgrade. The actual device is a Cisco Firepower 2130 Threat Defense (77) Version 7.0.4 . Cisco Adaptive Security Appliance Software Version 9.16(3)18. and we have a FMC that is Cisco Firepower...
Deployed a 3100 in chassis mode to the FMC a few days ago. All went to plan.Determined we needed to change the IP so decided just to delete the device from FMC and re-provision it.On the FTD via local-mgmt did a erase configuration. The device wiped ...
glsparks by Level 1
  • 85 Views
  • 4 replies
Hi,I'm using FTDv 7 managed by FMC v7. Logging issues are there and there is an error about FTD not synced.So, first step seems to solve the ntp issues. FMC GUI is there for ntp which I set and it seems to be ok, but I cannot find where is the ntp se...
Resolved! NGFW Sizing
Hi,Please I need an advise to determine the right NGFW based on the below requirements:- Each NGFW physical appliance should provide minimum of 240 Gbps Firewall throughput.- Each NGFW physical appliance must support minimum of 850,000 new TCP connec...
HIWe have several Policy based VPNs, I have read in a Cisco document that the sysopt permit-vpn is not supported with Route based VPN and I will need to configure access control for this, so that being said does this affect our policy based VPNs whic...
