Reverse NAT
Hi All,
I've got an interesting situation trying to get NAT working properly with a Cisco ASA 5510.
The Outside interface of the ASA is set as a public routable assigned to us by our ISP. Our ISP also routes several other networks (3 class C networks) to us. What I need to do is to NAT all of the IPs in these additional subnets to one single IP on the internal network.
Some other details:
Internal Network: 10.1.1.0/24
Internal Host (CSS11501): 10.1.1.65
ASA Inside Interface IP: 10.1.1.1
ASA Outside Interface IP: 207.67.38.17
ASA Outside Network: 207.67.38.16/29
Additional Networks: 164.110.112.0/24, 164.110.113.0/24, 207.74.12.0/24
NB: Networks/IPs have been changed to protect the innocent.
I have tried implementing the above with dynamic NAT rules with the "real" IPs on the outside interface and a single-IP NAT pool on the inside interface, but it doesn't seem to be working.
Any pointers on how I can achieve such a setup with a Cisco ASA5510?
Jon Marshall Tue, 06/12/2007 - 22:54
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Could you post relevant config. I would have thought the following should work
nat (outside) 1 164.110.112.0 255.255.255.0 outside
nat (outside) 1 164.110.113.0 255.255.255.0 outside
nat (outside) 1 207.74.12.0 255.255.255.0 outside
global (inside) 1 "ip address"
Jon
