NetConfig PIX support limitations
Jun 12th, 2007
  • Gold, 750 points or more
What're the potential pitfalls if NetConfig is used to change the local passwords on the unsupported PIX devices below? Is the NetConfig of LMS 3.0 any less limited in these aspects of PIX support?
http://www.cisco.com/en/US/products/sw/cscowork/ps2073/products_device_support_table09186a008073ebe3.html
2 NetConfig support is not available if the software version 7.0 or above is running on PIX Firewall devices.
4 PIX Firewall 535 is not supported by NetConfig.
Overall Rating: 4 (1 ratings)
Joe Clarke Tue, 06/12/2007 - 20:10
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The support mainly deals with templates. PIX OS 7.0 was not fully tested in terms of what CLI commands will be supported. Provided you push commands down that are understood, you should be able to configure a PIX running 7.x.
As for why the PIX 535 is not supported, I see no reason for that. It is managed the same as the other PIX models. I believe this is a legacy item carried over from RME 3.5, and Netconfig with the PIX 535 should work fine.
