2950switch problem
Jun 12th, 2007
hi everybody;
recently i have cisco 2950 problem
i have six cisco 2950
switchs,these switchs in which
one setting 6 channel-group.
last Saturday occurs that in the
switch two channel-group is
enable, then, other channel-groups
are disable. and remove cable
line, plug in cable line.
although, switch have normal
work, but after minute the switch
occours disconnected.
why........................
somebody and tell my why..
my 2950 cisco switch is
cisco WS-C2950T-24 (RC32300)
smothuku Tue, 06/12/2007 - 22:03
  • Silver, 250 points or more
Hi ,
Is there any messages or show log output from switch ...
Thx,
Satish
CSCO10892433 Tue, 06/12/2007 - 22:08
A diagram will be helpful too.
Best Regards
SSLIN
glen.grant Wed, 06/13/2007 - 04:23
  • Purple, 4500 points or more
If the switch is negotiating the etherchannel and the links are misconfigured then the switch will take down the link and it should post something in the log if the log is configured correctly.
