nat order and deny statements in acl's
Jun 12th, 2007
I have recently upgraded an ASA from version 7.0 to 7.2.2. After the upgrade a number of nat statements had been removed. This was related to icmp specific acl's in the nat acl's. After resolving this, the nat statements were re-added at the end of the nat list. The problem is that the ASA seems to match nat 3 rather than nat 2 (which is now at the end of the list) . I have added a deny to the access-list for the specific traffic for nat3 however the ASA still seems to be matching the acl for nat3.
I have used deny statements in nat acl's before and haven't had a problem however this doesn't appear to be working.
The acl's for the nat statements are below.
access-list nat0-inside line 1 extended deny ip
access-list nat3-inside line 1 extended deny ip
ess-list nat2-inside line 1 extended permit ip
Output for the packet-tracer is below.
Phase: 5
Type: NAT
Subtype: host-limits
Result: ALLOW
nat (inside) 0 access-list nat0-inside
nat (inside) 3 access-list nat3-inside
match ip inside outside
dynamic translation to pool 3 (No matching global)
translate_hits = 0, untranslate_hits = 0
Additional Information:
Any assistance would be apprecitated!
jaffer_sathik2010 Wed, 06/13/2007 - 04:45
You have created 3 access-lists with different names so confusion in the ordering!!! (Each acl has only one entry).
Regarding nat,it will be processed one after one from top to bottom.
[If you are using both static nat and dynamic nat ,static nat will take the priority].
In your senario,since you have attched Acl-3 with nat3, acl-2 will not come into play anymore.
So,remove the following command,
nat(inside)3 access-list nat3-inside
Add the following one.
nat(inside)3 access-list nat2-inside.
[Just changed the access-list]
Hope it helps.
acomiskey Wed, 06/13/2007 - 04:45
There isn't a nat command in your config which references nat2. The one in your config references nat3 which is why it is matching it.
david.buitendag... Wed, 06/13/2007 - 14:33
Thanks for your replies. I do have a global for the nat 2, I just didn't post it. I only posted the config relevent to the subject.
The nat 2 statement comes after the nat 3 statement as it was removed from the config after the upgrade. I was just enquiring if anyone has had any problems using a deny in the acl's for the nat statements and if a deny in the acl's would ignore the specific traffic for NAT? BUt not to worry... I will simply remove the current NAT statements and put them back in the same order that they were prior to the upgrade.
