LOG IS-IS CLNS-3-BADPACKET
Jun 12th, 2007
i have two routers attach for a tunnel. in both router i have configured a same area and i detected in bot router logs of:
%CLNS-3-BADPACKET: ISIS: L1 LSP, bad
max-area-addresses 0, ID 0100.6400.0034.00-00, seq 85, ht 0 from
0018.7425.6500 (GigabitEthernet0/0)
my problem is that my connectivity with my end system up and down (my ports and wires are correct)
my question is:
the problem is with my end system (ES) or problems with my hardware switch or cisco.
i havent ipv6 and my end system are devices lucent
mehdiraza Fri, 08/26/2011 - 05:45
Hello Erperts,
I've the similar problems... anything that you find to get resolve the issue.
BR//mehdi
