Upload logo's and files in CallManager 5.0
Jun 13th, 2007
I'm trying to upload logo and XML files in order to change the background on Cisco IP Communicator. In CM 5.0 you can upload file to TFTP folder but you can't choose a specific folder or directory to upload.
Any help is kindly appreciated.
Overall Rating: 4 (3 ratings)
Majdi Harb Wed, 06/13/2007 - 01:48
  • Silver, 250 points or more
hi
if u ask about how to upload ur files to a subdirectory within tftp superdirectory when u go to cisco unified os administration --> software upgrades --> upload tftp server file --> u find in this TFTP Server File Upload page below file * ... browse --> after u select the files from ur local pc to upload to tftp --> u can find below: ((Subdirectory of the tftp directory where file will be uploaded))--> write in the bar to the right the path u want to select/create example: if u write Desktops/320x212x12 this will upload ur files (images and List.xml) to the directory Desktops/320x212x12 under tftp
hth
please rate helpful posts
/majdi
