TCP connect doesn't establish through IPSEC tunnel
Jun 13th, 2007
I have IPSEC tunnel mode between router R1 and router R2.
Crypto session is UP. (sh crypto se)
But when I want to establish TCP connection (e.g. telnet 172.23.250.13 5023) from router R1 inside network to router R2 inside network session doesn't create.
R2
R2#sh crypto session detail | s 172.23.250.13
IPSEC FLOW: permit 6 host 172.23.250.13 port 5023 0.0.0.0/0.0.0.0
Active SAs: 2, origin: crypto map
Inbound: #pkts dec'ed 2 drop 0 life (KB/Sec) 4413690/286
Outbound: #pkts enc'ed 3 drop 0 life (KB/Sec) 4413690/286
R1
R1#sh crypto session detail | s 172.23.250.13
IPSEC FLOW: permit 6 0.0.0.0/0.0.0.0 host 172.23.250.13 port 5023
Inbound: #pkts dec'ed 0 drop 0 life (KB/Sec) 4509190/281
Outbound: #pkts enc'ed 2 drop 1 life (KB/Sec) 4509189/281
On another words, encrypted packets were sent by R2 but were not delivered to R1.
What's going wrong?
crypto ACLs on R1 and R2 are mirrored.
R2:
permit tcp host 172.23.250.13 eq 5023 any
R1:
permit tcp any host 172.23.250.13 eq 5023
and command (sh access-l) shows that traffic was matched on R1 and R2.
P.S. Without IPSEC TCP session can be established, so it's not routing or something else.
most common reasons is if a router, PIX Firewall, ASA or VPN Concentrator loses dead peer detection (DPD) keepalives on the path.
DPDs are used in order to verify if the remote peer still answers, because it is unsafe to keep a connection active if the remote device is dead. To a device that loses these packets, it means that the peer no longer responds to ACK for DPD, and therefore, is not reachable.
The Internet Key Exchange (IKE) keepalive packets are sent every 10 seconds, by default. Once three packets are missed, an IPsec termination point concludes that it has lost connectivity with its peer.
In order to resolve this issue, issue the crypto isakmp keepalive command on the Router. This allows the gateway to send DPD messages to the peer.
