StandBy / Active PIX
jaffer_sathik2010 Wed, 06/13/2007 - 04:09
Hi Neo,
Other than that,Both unit should run same software versuon and H/w model also should be same.
If you are running PIX s/w version 7.0 or later then you can get a relaxation on running the similar version of s/w in both units but the H/w version should be same.
vitripat Wed, 06/13/2007 - 08:10
  • Gold, 750 points or more
Hey Neo ..
Have answered both these questions in your other post.
Vibhor.
jaffer_sathik2010 Wed, 06/13/2007 - 19:41
Does n't matter what PDM version do you running on the pix box.
But the firewall image version and h/w versio including size of flash memory /ram memory etc., should be same.
--Jaffer
