An annoying but not urgent problem with 7960 on CCME 4 system
Jun 13th, 2007
I have a new CCME installation with mainly 7912 phones and just 1 7960. Problem is the 7960 cant see the ringlist and so only has the two default chirps. The 7912's are fine and can see the ringlist i created.
I have two files on the flash RingList.xml and DistinctiveRingList.xml and the following two lines in my config "tftp-server flash:DistinctiveRingList.xml" and "tftp-server flash:RingList.xml". Like i said Its not urgent but just wondered if anyone has experienced the same problem.
regards
colin
Overall Rating: 3 (1 ratings)
Paolo Bevilacqua Wed, 06/13/2007 - 15:27
On the router, please enable "term mon" and "debug tftp events". Go to rings preferences in the 7960. You should see the file request and correct any file naming casing problem with the "alias" option to "tftp-server".
Hope this helps,please rate post if it does!
ReadersUK Wed, 06/13/2007 - 23:22
Hi Paolo
Thanks for your reply. I found problem, me!. The first view is the two chirps but when you press select you see all the ring tones.
Colin
