yjdabear Wed, 06/13/2007 - 05:51
  • Gold, 750 points or more
show interface status err-disabled
or
show interface status | include err-disabled
Martin Ermel Wed, 06/13/2007 - 05:57
  • Blue, 1500 points or more
You should be able to use:
show interfaces status err-disabled
to view the ports with status error disabled.
See this doc for details on error disabled ports:
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a00806cd87b.shtml
if a port changes its status to err-diabled it records a syslog message; so you can use a syslog collector to get these messages and further process them if the collector supports this (email, etc)
lfranchini1 Wed, 06/13/2007 - 07:26
If I had no error-disabled ports I should not get a response from the switch correct?
I get a blank command line from the switch when I tried the command.
Martin Ermel Wed, 06/13/2007 - 08:01
'no response is a good response'
if you enter the command and you are not getting a listing then there is nothing to list..e.g there are no ports in error disabled state;
do a
to see a list of all ports with their status
