object-group acl example
Jun 13th, 2007
i'm just converting my ACLs to use object-groups and just wanted ti check the ACLs I have written are OK. To start with I have some ACLs of:
access-list example permit ip 192.x.x.0 255.255.255.0 10.x.0.0 255.255.0.0
and some object-groups of:
object-group network UK_Network
description subnets in use on UK LAN
network-object 192.x.x.x 255.255.255.0
network-object 10.x.0.0 255.255.0.0
object-group network Canada_Network
the access-list I have written to use the object-groups is:
access-list example permit ip object-group UK_Network object-group Canada_Network
does this look right?
thanks
Jon Marshall Wed, 06/13/2007 - 06:39
It looks fine other than the 10.x.0.0 entry in the UK_Network object-group. Do you need this.
Jon
w.halliday Wed, 06/13/2007 - 06:55
Hi Jon
my fault with the notation of the subnets- should read:
network-object 10.20.x.x 255.255.0.0
network-object 10.1.x.x 255.255.0.0
the network object-group acl's seem easy enough- would it be Ok if I ran some port, protocol and icmp ACLs past you?
w.halliday Wed, 06/13/2007 - 07:07
thx
here are some object-groups I've written and i'm juts writing the access-lists currently. Also wondering about best testing and implementation method- presumably one access-list at a time and out of hours!?
object-group protocol proto_grp_1
protocol-object udp
object-group service OWA_AD TCP
description TCP ports for Outlook Web Access and Active Directory
port-object eq ldap
port-object eq www
port-object eq domain
port-object eq https
port-object eq 42
port-object eq 88
port-object eq 135
port-object eq 445
port-object eq 3268
port-object eq 3269
object-group service OWA_AD UDP
description UDP ports for Outlook Web Access and Active Directory
port-object eq ldap
port-object eq 42
port-object eq 88
port-object eq 135
port-object eq 445
port-object eq 3268
port-object eq 3269
object-group service External_Addresses TCP
description TCP ports for External Addresses
port-object eq www
port-object eq smtp
port-object eq pop3
object-group service External_Addresses UDP
description UDP ports for External Addresses
port-object eq 10000
object-group protocol TCP
protocol-object tcp
w.halliday Wed, 06/13/2007 - 07:52
Hi J
my original access-lists are:
access-list if-out permit tcp any host 62.x.x.232 eq www
access-list if-out permit tcp any host 62.x.x.235 eq pop3
access-list if-out permit tcp any host 62.x.x.234 eq smtp
access-list if-out permit tcp any host 62.x.x.234 eq www
access-list if-out permit tcp any host 62.x.x.235 eq www
access-list if-out permit tcp any host 62.x.x.235 eq smtp
new object-groups:
object-group network External_Addresses
description External Addresses
network-object host 62.x.x.234
network-object host 62.x.x.235
updated access-lists:
access-list if-out permit tcp any object-group External_Addresses eq smtp
access-list if-out permit tcp any object-group External_Addresses eq www
how's that look? cheers for help- been sidetracked on to some other stuff unfortunately
Jon Marshall Wed, 06/13/2007 - 23:20
Yes that looks fine to me. I agree that it is best that you test this out of hours just in case you have missed anything.
Let me know how you get on
Jon
w.halliday Thu, 06/14/2007 - 00:04
Jon thanks.
I have multiple examples of pairs of rules in separate access-lists which reference the same source and destination networks that are both getting hit- how does this work- do I need both lines?
w.halliday Thu, 06/14/2007 - 00:39
yup sure
access-list 1 permit ip object-group UK_Network object-group Canada_Network
access-list 2 permit ip object-group UK_Network object-group Canada_Network
both getting hit- why are both needed- wouldn't just one do the job?
Jon Marshall Thu, 06/14/2007 - 01:03
Will
Where are these access-lists applied ie. which interfaces on they applied to and in which direction.
ordinarily you don't need to have the same access-lists but without some context it's difficult to say.
Jon
w.halliday Thu, 06/14/2007 - 02:37
neither are applied with an access-group command. UK_Network is on inside and Canada on outside.
Jon Marshall Thu, 06/14/2007 - 02:50
Will
Okay, i'm confused now. How are you getting hits on them if you have not applied them on any interfaces ?
Jon
w.halliday Thu, 06/14/2007 - 07:32
good- sort of as that had been confusing me too! this config is something I have inherited and I'm just coming to terms with (and the counters have been cleared recently). I've bene taske dwith cleaning up a config which has had numerous people working on it over last few years.
I have two access-lists applied to interfaces as follows:
access-group if-out-owa in interface outside
access-group inside_access_out in interface inside
access-list if-out-owa permit tcp any host 62.x.x.x eq www
access-list if-out-owa permit tcp any host 62.x.x.x eq https
access-list inside_access_out deny ip any host ip_of_some_virus_server
access-list inside_access_out permit ip any any
