Jon Marshall Wed, 06/13/2007 - 06:34
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
You could
1) Use an object-group to define the IP's and then you only have to enter one line in the access-list.
2) You could use 66.333.33.0 255.255.255.248
but this would cover .1 -> .7 and it depends on what the other IP addresses are used for.
3) Type them in individually as you say.
Jon
